Power window adjustment -- searched
96 HX w/ power windows...
It doesn't seal all the way. I tried moving the track back and fourth (on the front) but that makes it leak air either in the front or in the back, no matter how I adjust it.
The previous owner had window problems, apparently replaced the motor, but didn't get it back into place correctly. It rolls down a little too far, and doesn't roll up far enough. I'm thinking I need to make the whole thing move up a little, but with the door panel off and me poking around, I can't see how to do that at all...
Any ideas?
Any ideas?
Re: Power window adjustment -- searched (9civic5)
You need to have the panel off so that you can watch things happening and usually the problem will present itself and/or give you the ability answer questions for people willing to help you...outside of that you will have equal luck with a magic 8-ball or psychic friend.
I got the same problem man. First my windows wouldn't go up, fixed that... now they won't seal on the drivers side. Like you I tried to adjust it, I think maybe a new track would fix it, but I am not totally sure. If anyone knows a solution for all of us post it up, I can't stand the air noise.
hondapwr
07-28-2007 06:55 PM
