Is a Pilot Bearing and a Release bearing the same thing?
I am a (Trial User) Army
The bearing that comes with aftermarket clutch kits, that's the pilot bearing right? Is that the same thing as the release bearing? Just two different words describing the same thing?
Re: Is a Pilot Bearing and a Release bearing the same thing? (litterbox)
A pilot bearing is a regular style bearing that is installed in the flywheel to support the main shaft of the transmission.
The release bearing, or throw out bearing, is the one that gets installed between the transmission and the clutch, on the main shaft. This is what pushes on the pressure plate when you push the clutch in.
Re: Is a Pilot Bearing and a Release bearing the same thing? (Marauder)
Ok, now the pilot bearing ususally comes with aftermarket clutch kits correct?
Does it look pretty similar to the release bearing?
Most clutch kits will include both bearings. No, they don't look similar. The pilot bearing will be about 1.5 inches in diameter whereas the release bearing will be about 3 inches in diameter. The release bearing will fit on your slave cylinder inside the transmission. The pilot bearing, as mentioned before, will go on your flywheel.
B96v6
B96v6
They are completely different.
Not all clutch kits some with a pilot bearing but most come with a release bearing.
Pilot Bearing
Throwout Bearing
Pilot Bearing
Throwout Bearing
Ok, my kit came with the release "throwout" beaing.
I called inline pro and they told me the pilot bearing is actually a part of the flywheel that can be replaced if worn. I'll look and see if it's on the flywheel when i get home.
Re: (Mr_WETTY)
Stop Post whoring.
Whenever i do a clutch i would always want to replace that bearing just because the tranny is off, and the flywheel is off. What better time.
Re: (litterbox)
another thing, you have to remove the flywheel from the engine in order to remove the pilot bearing. FYI. you can tap it out from outside to inside. (when the flywheel is off ofcourse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">A pilot bearing is a regular style bearing that is installed in the flywheel to support the main shaft of the transmission.
The release bearing, or throw out bearing, is the one that gets installed between the transmission and the clutch, on the main shaft. This is what pushes on the pressure plate when you push the clutch in.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">They are completely different.
Pilot Bearing
Throwout Bearing
This guy is 100% correct.
Pilot Bearing
Throwout Bearing
Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">FYI, k series flywheels do not need a pilot bearing.</TD></TR></TABLE>
Is it in the crank? Something has to support the input shaft... either a bearing or a bushing.
Re: (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek »</TD></TR><TR><TD CLASS="quote">
Is it in the crank? Something has to support the input shaft... either a bearing or a bushing.</TD></TR></TABLE>It's a bushing.
Re: (litterbox)
Also, when you change a clutch, its also a good time to get a new rear mail oil seal. Especially if there is a lot of miles on it already, it only takes a few more minutes to change.
crxpwr1
11
10-02-2006 03:45 AM
