my shifter shakes!
Re: my shifter shakes! (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">my shift **** shakes at idle? do i need a new shifter bushing?</TD></TR></TABLE>
It's possible for the shifter to shake excessively if you have a worn bushing somewhere on the linkage. You should get under the car and check them out!
Re: my shifter shakes! (BLUE EH3)
its pretty normal unless it shakes alot and vibrates. if so then check the bushings and also where the shifter connects to the change rod. check the bolt there and maybe tighten it up "jus a little bit"
Re: my shifter shakes! (babble)
if it shakes, shake it back.
just pickup energy suspension shifter bushing kit for your car. it will be the best $12 you will ever spend
kragen is your friend.
Help we my pennies
Re: my shifter shakes! (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">if it shakes, shake it back.
kragen is your friend.</TD></TR></TABLE> yes!
its probably bushings you could have some bad engine mount bushings but a little shake isn't bad mine dose it a little to at idle too
Electrician
You might need new bushings. Mine did that with the OEM bushings, being 10 years old. I replaced the with Energy Suspension polyurethane ones, no shake at all. Hardly noticeable.
jacoop86
10
05-23-2006 11:53 AM
137
06-17-2005 08:00 AM
BAZ
07-29-2003 09:29 PM
