how do you remove cam gears when the cams are not in the car
i am wondering if there is anyway to take the cam gears off when i have the cams out of the car thanks
Re: how do you remove cam gears when the cams are not in the car (turbodreamz0385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodreamz0385 »</TD></TR><TR><TD CLASS="quote">have somebody else hold the cam gear realy tight</TD></TR></TABLE>
Unceasing Measure
Re: how do you remove cam gears when the cams are not in the car (aspec101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aspec101 »</TD></TR><TR><TD CLASS="quote">use your impact gun and you can do it by youself </TD></TR></TABLE>
Yup.
Yup.
Solbros Owns Me
Re: how do you remove cam gears when the cams are not in the car (skater5067)
don't impact it back on!!! May break the cam.
What cam is it?? Some have hex heads built into the middle of the cam you may use, and some have holes to help with t-belt installation. If this isn't the case, must have D series or something, then stick it in a vise with SOFT JAWS...ie, aluminum faces to keep from scratching the crap out of it. Or stop by a local garage and slip a dude 5 bucks for lunch, it will take him 2 seconds to zap it off
Re: how do you remove cam gears when the cams are not in the car (Evs-One)
try to get a old timing belt and wrap it around the gear teeth with one hand and then impact it out with the other hand
Re: how do you remove cam gears when the cams are not in the car (SkAnK_aSS_BRyAn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkAnK_aSS_BRyAn »</TD></TR><TR><TD CLASS="quote">Call your mommy.
or put a towel around it and use a vice.</TD></TR></TABLE>
AHHHHHHH.....NOOOOOOOOO!!!!!!
Vice+Cam=Very bad things
na they were ls cams i got it off there is like a nut thing on it and i just but a adjustable wrench on it and held it i didn't notice it was there before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">Or stop by a local garage and slip a dude 5 bucks for lunch, it will take him 2 seconds to zap it off</TD></TR></TABLE>
Classic and there is always someone to do this
Or get a bench clip, you know those huge clamps that are bolted to a bench, and get some wood between the metal of the clamp and the cams. Clamp it down slowly and just tight enough to loosen the bolt. GL.
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote"> Some have hex heads built into the middle of the cam you may use,f</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skater5067 »</TD></TR><TR><TD CLASS="quote">na they were ls cams i got it off there is like a nut thing on it and i just but a adjustable wrench on it and held it i didn't notice it was there before</TD></TR></TABLE>
Teamdiesel
01-06-2006 12:59 PM
