Parts question
Parts question
Here is the deal... I was doing some work on my car and when I was taking of one of the front wheels I noticed the entire hub was loose. I could move the tob and bottom of the wheel in towards the car. The problem is I don't really know what the part is called or what to look for. It's basically the piece that locks the hub into place. It's the piece that the axle sits on.
If anyone knows what the piece is called or if they could get me a part number for it, I would really appreciate it.
Re: Parts question (SOHC4life 96)
if you are talking about your rotor then who cares if you can move it since it is held in place by the tire when you screw the lugs on. but if it is the entire knuckle that you can move then that is a problem.
Re: Parts question (cwd14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwd14 »</TD></TR><TR><TD CLASS="quote">if you are talking about your rotor then who cares if you can move it since it is held in place by the tire when you screw the lugs on. but if it is the entire knuckle that you can move then that is a problem.</TD></TR></TABLE>
Yes it's the entire knuckle and yes it is a problem. And I need the part to fix it.
Re: Parts question (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">That's a bad wheel bearing. You'd need to take the hub off and press the old one out and a new one in.</TD></TR></TABLE>
Yepp
Yepp
Re: Parts question (HondaJack)
No, I inspected the wheel bearing and it's fine.
I got a couple pictures of it.
Re: (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">FYI: Part number 1 is a brake caliper boot rebuild kit.</TD></TR></TABLE>
Ahhhh, thank you. So I'm not even close.
Bump I really need to know what the part is.
Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">replace the hub and wheel bearing and call it a day </TD></TR></TABLE>
I'm not going to buy a new hub, my hub is fine. The part I took out needs to be replaced.
Bump for an answer
Bump for an answer
is that is or is it not one of the races from the wheel bearing? usually when you ride on a bad wheel bearing for too long without noticing, you can f up the suface of the hub that the bearing gets pressed onto.. which is why i personally always change wheel bearings and hubs all at once.. but your also the one that said your wheel bearing is fine so if your that sure of yourself why are you on here for answers at all?
bad wheel bearing will not mess up your hub unless you do some real damage.
NOTE: THE RACE IS OUT OF THE BEARING. THIS IS BAD!!!!! THE BEARINGS ARE SEALED AND ARE NOT SUSSPOED TO DO THAT.
You need a wheel bearing.
Ek Forever y0!
Re: (90dteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dteg »</TD></TR><TR><TD CLASS="quote">NOTE: THE RACE IS OUT OF THE BEARING. THIS IS BAD!!!!! THE BEARINGS ARE SEALED AND ARE NOT SUSPPOED TO DO THAT.
You need a wheel bearing.</TD></TR></TABLE>
Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">is that is or is it not one of the races from the wheel bearing? usually when you ride on a bad wheel bearing for too long without noticing, you can f up the suface of the hub that the bearing gets pressed onto.. which is why i personally always change wheel bearings and hubs all at once.. but your also the one that said your wheel bearing is fine so if your that sure of yourself why are you on here for answers at all? </TD></TR></TABLE>
I guess it is the race from one of the wheel bearings. However I didn't know that, that's what I was asking.
So all I need to do is buy a new wheel bearing and get it pressed back in and I should be fine? (for the time being, I don't have $130 for a new hub right now)
Ek Forever y0!
Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
So all I need to do is buy a new wheel bearing and get it pressed back in and I should be fine? </TD></TR></TABLE>
Try that
Try that
tigueremalo
17
05-17-2006 08:41 PM
xlusiveracer
03-15-2006 01:25 PM
