Few Questions: 94 LS into 92 hatch
I've read the stickies, searched, done alot of stuff. Just want some answers.
I have all of the LS mounts. Do I need others/different ones?
What radiator do I use? I currently dont have one on the shell.
Will aftermarket header and intake fit under the hood O.K.?
Any help is appreciated. Thanks.
Guest
Posts: n/a
Re: Few Questions: 94 LS into 92 hatch (accordheat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordheat »</TD></TR><TR><TD CLASS="quote">I've read the stickies, searched, done alot of stuff. Just want some answers.
</TD></TR></TABLE> All the mounts fit. You can use your stock eg radiator. and yes header and intake all fit ok...
Re: Few Questions: 94 LS into 92 hatch (chillis)
thanks for the quick response
I currently do not have a radiator and was just thinking about aftermarket ones. (Fluidyne for example) Any big benefit to one of those? If not, ill just pick up an EG rad.
A stock EG radiator will work fine. The aftermarket ones are good, but unless you have boost plans in the future the stock one will work with no problems. I am running a stock civic radiator with my C1 swap. Hope this helps.
Re: Few Questions: 94 LS into 92 hatch (ek forever guy)
or you could always go get a cheaper aftermarket radiator for like a little bit under 100$ to your door and not have to deal with buying someone's used radiator
TeggerLS
09-13-2006 03:38 PM
