help!! my civic cuts out at high speeds?
hi guys, i have just imported a honda civic siR2 from japan, its on a 1993, (b16a). when im nailing in 5th gear doing about 122mph with my foot to the floor it just cuts out.
is this the limmiter on these imports?
cheers
It's the ECU, I had the same problem with my EX at 123, didn't cut out, but it backed down to like 119 or so, still had more left in it so I don't think it was topping out... then went back up to 123 right away (so u could tell it was a limiter)...you can get it chipped and have the limiter removed
Re: (sir222)
1]wecome to HT
2]typical noob question:
no real reason for going that fast..sorry to break it to you.. only way i would be doing it is if i was racing for slips , big $$$$ or on the autobahn highway..and if you still have your gov on your car doesnt sound like you were were doing either.. YOUR THE REASON MY INSURENCE IS SO HIGH.. THANKS @#%HOLE!!
jdm ecu's have a tendency to have a lower set gov than usdm..
Modified by 87shytwhip at 1:57 PM 9/11/2006
Re: (87shytwhip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87shytwhip »</TD></TR><TR><TD CLASS="quote">1]wecome to HT
Modified by 87shytwhip at 1:57 PM 9/11/2006</TD></TR></TABLE>
Wow, flames that bad and he can't even use proper grammar or spell words right. This post makes me want to die.
Re: (fizix_skate)
yup its the ecu get it chipped, and your good to go as fast as your motor will let you , but i wouldnt recomend going so fast unless your at the track
Unceasing Measure
Why do you need to go more than 122mph again? If you're using that particular ECU with the corresponding engine, there's no back-straight or dragstrip this side of the moon that would allow your shitbox to reach those speeds. If you're doing it on the highway, I can only hope Darwin snatches you away without interfering in the lives of any innocents.
ok, what is wrong with you people that keep havin a go at me cos u think im doin these speeds on the roads!! it was on a track!!!! near castle-coombe so y dont you just give it a rest! and im sure its not just your insurance that is high...mine s too yea TW*T!!
thanks to those that are giving some good advice!
Re: (fizix_skate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate »</TD></TR><TR><TD CLASS="quote">
Wow, flames that bad and he can't even use proper grammar or spell words right. This post makes me want to die.</TD></TR></TABLE>
I could contact some wisconsin based hitmen for you if you'd like?
Unceasing Measure
Re: (sir222)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir222 »</TD></TR><TR><TD CLASS="quote">ok, what is wrong with you people that keep havin a go at me cos u think im doin these speeds on the roads!! it was on a track!!!! near castle-coombe so y dont you just give it a rest! and im sure its not just your insurance that is high...mine s too yea TW*T!!
thanks to those that are giving some good advice!</TD></TR></TABLE>
Post some proof, because I think you're lying You also type like a toddler on crystal meth.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Post some proof, because I think you're lying You also type like a toddler on crystal meth.</TD></TR></TABLE>
LMAO! dude you're funny as hell!
cheers
yes they have rev limiters. stop trying to hit 122mph!
cheers
Unceasing Measure
Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">Mine has a speed gov @ 190 km, and i do it on the highways, Its fun !who gives a ****, just get out of the way and nothing will happen.</TD></TR></TABLE>
What happens if you blow a tire or a deer runs out in front of you? Way to think ahead!
Re: (Archidictus)
Finally a buckeye with a brain!
I'm pretty sure he's lying too. I seriously doubt his newly acquired civic does 120 mph on the track.
Re: (Malakai)
actually 190kph is only 117mph. and yes it's still fast, uncalled for, and you still have much to learn my young padawan!
Unceasing Measure
Re: (2000EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EM1 »</TD></TR><TR><TD CLASS="quote">Finally a buckeye with a brain!
I'm pretty sure he's lying too. I seriously doubt his newly acquired civic does 120 mph on the track. </TD></TR></TABLE>
Well he IS looking for some JDM red emblems for it, so maybe it'll go 120+ after that tasteful modification
whay are you on about! the track i have tried it on is partly an old unused runway and the long straight is more than enough to hit that speed, just because i have just imported it does not mean it wont hit 122 on a track... dur!!!!
Unceasing Measure
Re: (sir222)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir222 »</TD></TR><TR><TD CLASS="quote">mmmm well done!</TD></TR></TABLE>
Did you read my reply in your other thread?
