Whoom whoom whoom....WTF?!?!?!
When ever I am rolling,
the wheels make this sound; whoom whoom whoom whoom.
WTF?! People have told me to rotate tires, check the brakes, etc.
Could it be axles, un-balanced wheels, streering rack, a bearing,
what? It's driving me nuts knowing my car is'nt 100% healthy.
Please shoot me some advice. I know someone's delt with this before.
Car is '93 si hatch/95 US GSR heart.
All help/advice is much appreciated.
Thanks for looking!
Thanks for looking!
Re: Whoom whoom whoom....WTF?!?!?! (SkoundrelUSA)
Tires are damn near brand new.
When i'm rolling down the street, whoom whoom whoom is what you hear
coming from the front suspension area.
Re: (iLOVEthatEMone)
It's been making this noise for a while.
It's just been getting progressively worse.
I've tried different wheels, no improvements.
Re: Whoom whoom whoom....WTF?!?!?! (v8killa91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8killa91 »</TD></TR><TR><TD CLASS="quote">that happend to my booy it was hit camber was so bad so long it messed up his bearrings. </TD></TR></TABLE>
wheel bearings?
wheel bearings?
Re: Whoom whoom whoom....WTF?!?!?! (bgcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgcrx »</TD></TR><TR><TD CLASS="quote">wheel bearings?</TD></TR></TABLE>
Yes.
Yes.
yeah, its definitely your wheel bearings...i have the same problem on my supra right now, mine are pressed in, im not sure how the civic ones are since ive never had a problem yet
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">do the wheel bearings need to be hydraulicly pressed in and out?</TD></TR></TABLE>
Ya
Probably need a new hub too. Should come in under $200 for everything.
If you want to make sure it's the wheel bearing, jack up the car and try to wobble the wheel.
Ya
Re: (jolt-tsp)
Wheel bearing, about 70 a side, or you could just source a new hub assembly. I got another hub fro 40 from a junk yard as opposed to 70 for the bearing and another 20 to get it pressed in and out.
Re: Whoom whoom whoom....WTF?!?!?! (Sketch_hs)
Thanks too all who responded. Your help is greatly appreciated.
When I turn either direction, the steering wheel shakes a bit and
the noise gets louder.
Gotta get back to watching season two of Lost on dvd.
grammer nawzi
I never would have guessed you listen to ICP, what a joke. Speak english.
OP, like stated, most likely your bearings.
wheel bearings. Grab a front wheel, and shake it back and forth, to and from you. If you feel play like something's loose, its your wheel bearing. Like someone else said, do all 4. cause once one goes bad, the others follow.
Re: Whoom whoom whoom....WTF?!?!?! (EkLanta)
I had this same problem shortly after I swapped motor.. forgot to tighten the axel nuts :-x.. wouldnt hurt to check them
Hope this helps in some way shape or form
-Cody
-Cody
///Nick
03-09-2012 11:43 AM
aznromeo4u
06-28-2010 07:08 AM
ekcivic9
10-15-2005 01:49 PM
