Del Sol Si need help with a MIL/Engine Light... Help..
Just swapped in a b16a3 (complete tune up) in my del sol si, which originally was D16z6. The engine light wasn't on for the first two week I drove the car and Vtec kick in hard. Since I smogged the car few days ago, the engine comes on after 3,000 RPM or so and Vtec will not kick in. I wonder do anybody have this symptom before... Also, I bought this shell that with the SRS light on. I assume previous owner have replace airbag, but neer reset the SRS system. I wonder how do you reset the SRS where I can elimate the light... THank
318 Curves, 11 miles
Re: Del Sol Si need help with a MIL/Engine Light... Help.. (95GSRBOI)
go to autozone. They'll let your borrow an OBD2 tester for free. Find out what the code is and post it.
Re: Del Sol Si need help with a MIL/Engine Light... Help.. (Vindicator9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">find out what the CEL code is and let us know.
https://honda-tech.com/zerothread/1171263
chris</TD></TR></TABLE>
It's a OB1.. Do they have a tester I can pull a code on?
Before I pull a code.. Is there any assumption what it might be the problem? Such as 02 sensor, bad catalytic converter or so?
will you follow the link above and let us know the code you are getting????? PLEASE
see this post by teamnextgenchris
chris
he is showing you how to FIX YOUR PROBLEM
you click on that underlined string of text and follow the instructions... its called a LINK
after you follow it you let us know what number you have, you can either consult your helms manual or post here and most people will ignore you and not give you any real help.
chris
USDM.LOVE
05-21-2007 05:04 PM
PearlBlueType-S
09-05-2005 09:09 PM
