CHECK ENGINE LIGHT ON BUT NO CODE.......
B A N N E D
I was throwing 3 codes and I fixed them all. The three were map sensor, tps sensor, and the iat sensor. Once they were all fixed the the check engine light came on 2 minutes later. I disconnected my battery and disconneted my ecu. So when I go to check my codes with the wire it doesnt flash or anything. The check engine light just stays. Any help appreciated I searched and no info related to my issue motor is a obd 1 h22 running crome.
1 Post
Re: CHECK ENGINE LIGHT ON BUT NO CODE....... (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">Solid cel usually means bad ecu or bad map on the chip.</TD></TR></TABLE>
solid CEL when the jumper is jumped means no codes.
check your backup/radio fuse to make sure it's not blown.
Chris
Chris
Re: CHECK ENGINE LIGHT ON BUT NO CODE....... (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
A bad ecu/chip will cause a solid cel whether jumped or not.
kaoss_11
09-10-2006 04:14 PM
h22turbolude
12-25-2003 03:54 PM
