EM1 Takes like 10 turnes to start the car after putting gas in
Every time I put gas in my 2000 SiR it take forever to start after. I have a 255 pump in it. Any ideas?
Re: EM1 Takes like 10 turnes to start the car after putting gas in (TwoKSiR)
sounds like the pressure isnt there... what happens if you turn the key and wait for the pump to prime (like wait 5-6 secs) then try to start it?
new fuel filter, and i have ryed to prime it several times, its driving me nuts.
try opening ur fuel door and taking the gas cap off
get some1 to turn the switch on and listen for the pump 2 turn on
if no sound then
your connection to your fp could be bad
or the fuel pump is going out
i had the same prob with my eg 4dr
turned out to be a bad connection b/t the ecu and fp
if no sound then
I have a gauage and it looss pressure and regauns full pressure as soon as I prime it. Its a 255, I dont have to take the gas cap off to hear it, it make the same noise they all do.
Re: EM1 Takes like 10 turnes to start the car after putting gas in (doublejz)
How the hell does that post help? That's an A/F Ratio guage...
He doesn't need an A/F ratio guage, he needs more pressure for whatever reason.
The pump is turning on or it wouldn' t be driving, so what's the possible corprits:
- clogged fuel filter (he said he changed it)
- FPR is fucked up (possible)
- fuel rail went...bad (unlikely)
- clogged injectors (still unlikely, or it'd be breaking up)
- evap purge solenoid (maybe..)
What else is there? I'm sure I'm leaving some **** out
Those are what I'd check first though...
Re: (Syndacate)
I posted the Air/Fuel gauge, its mine and I can't find the wiring diagram, I got alot of responces for this so I thought I would post the link here by chance.
The chick in my avatar is
http://www.jhpusa.com/catalog/...=1094
Its the JDM ***** t-Shirt that JHPUSA.com sells
And thanks for the help on the fuel pump issue. When I get my new motor in I will try the ideas. I got the pump from my firends DC2 and it didn't have any problems in it.
gtaccord
15
03-05-2014 08:27 PM
hoperegrine
01-29-2007 08:51 PM
ATS*Mark
10-26-2004 08:16 AM
