differences in 96-98 and 99-00 2 door trunks?
i've bandaided this problem for a while, but want to finally fix it.
i bought a 97 honda 2 door trunk lid and put it on my 2000 coupe.
when i did that, there is a huge gap toward the rear window that leaves enough space was water to get in.
currently i added a layer of weatherstripping around the oem one which is still attached to the body of the car.
Am i missing something in the trunk?
Re: differences in 96-98 and 99-00 2 door trunks? (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">This is a good question, I was under the impression that they were both exactly the same...</TD></TR></TABLE>
the weatherstripping i added is about 1/2 inch thick, just to make up for the gap
Re: differences in 96-98 and 99-00 2 door trunks? (igo4bmx)
I put a 00 trunk lid on my 97, I noticed it did not fit perfect around the window. I have heard that 96-98 has a different part number as to the 99-00 lid.
HT White Ops
96-98:
LID, TRUNK - 68500-S02-A01ZZ
WEATHERSTRIP, TRUNK LID - 74865-S04-003
HINGE, R. TRUNK - 68610-S01-J00ZZ
HINGE, L. TRUNK - 68660-S01-A00ZZ
99-00:
The parts are identical, according to the HondaNet 2000 EPC.
99-00:
HT White Ops
Re: (igo4bmx)
Are you sure you didn't select a painted one? Because all the painted ones have different parts numbers. I got those part numbers from HONDA. HondaNet 2000 is Honda's EPC that they just recently stopped using (as of 2002).
HT White Ops
68500-S02-A01ZZ 99-00
68500-S02-A01ZZ 96-98
From slhondaparts *uses a web-based version of honda's epc* ..... hondaautomotiveparts are wrong, or you selected the wrong part.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">68500-S02-A01ZZ 99-00
From slhondaparts *uses a web-based version of honda's epc* ..... hondaautomotiveparts are wrong, or you selected the wrong part.</TD></TR></TABLE>
Word, that's a reputable site..
If they're the same part # obviously it's the same part...
So you screwed up installing it....not sure how, but whoops.. fix it
HT White Ops
Re: differences in 96-98 and 99-00 2 door trunks? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">The Honda parts catalog indicates that all '96-00 2dr Civics share the same trunk lid.</TD></TR></TABLE>
That's what I said .... but no, they don't believe.
Re: differences in 96-98 and 99-00 2 door trunks? (Eran)
i have a 99 si trunk on my 97, fits exact, but remember when removing an oem part and installing another, u must adjust. every car's trunk sits diffrent, no matter what.
adjust, adjust, adjust...
spooncivicsi
22
07-16-2007 12:16 AM
68500s02a01zz, 68610s01j00zz, 74865s04003, 9698, 9900, difference, door, epc, hinge, honda, hondanet, install, trunk, trunks, weatherstrip
