Big Surprise, Fogs went out.
Password JDM fogs, 3 weeks after installation they stopped working. The switch still lights up, but the fogs dont. What should I look for first. It rains alot where I live, could some of the wiring in the bumper have gotten wet???
Re: Big Surprise, Fogs went out. (B16B_coupe)
i had the same problem... i just went out and picked up a new relay... they work now... try that... auto zone should have a relay..
HRD PKR
Re: Big Surprise, Fogs went out. (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">back when i had no name foglights, the fuse got wet and salt also got in there. Check the fuse, might be dirty...</TD></TR></TABLE>
u mean a blown fuse.. and not a dirty one..
Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjaser »</TD></TR><TR><TD CLASS="quote">my 96 fogs do that too. jus check the grounds</TD></TR></TABLE>
I got a 97, so it was your grounds??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">
u mean a blown fuse.. and not a dirty one.. </TD></TR></TABLE>
no mine was dirty from the salt. It wasn't blown, just the contact spot were so dirty power didnt get thru.
H-T White Ops
Is it the DEPOs they sell? If so then it's probably a bad ground.
I had DEPOs on my '98 EX coupe and had nothing but problems (repeated wiring issues - it would just flicker or stop working and start working if you kicked it, also leaked no matter how well they were sealed).
Switched to Esuse lights and haven't had an issue.
Re: (Eran)
I was messing around with it today, and I could hear the relay go on and off. Also the switch still lights up. I also checked the grounds. The one under the hood was connected to the ground bolt, but i could pull it out without removing the bolt. I connected it as good as possible but they still didnt work. Also I am pretty sure the one under the dash is hooked up two but didnt get a good look. Anyone know what the problem would be. If Iwere to blow a fuse would the switch still light up??
Re: (turnsignalandy)
i put some fogs on a 98 hatch back last summer, they were a depo kit the switch went out about 2 months later. does any one know where to get the switch for it? i was under the impression that the password switch and the depo switch weren't compatible. i would like to know. i know it is the switch because i ran a power wire from the fogs to the fuse box and they worked.
Re: (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">Is it the DEPOs they sell? If so then it's probably a bad ground.
Switched to Esuse lights and haven't had an issue.</TD></TR></TABLE>
are you kidding? i have had my depos installed for over 8 months with NO issues. They survived a minus 40C* Canadian winter!, a lot of people disregard the fact you should wrap all the connectors in electrical tape to ensure they are completely waterproof and don't come disconnected by themselves.
just check all connections and grounds
Re: (vtecftw)
will water expletive up the connecters in the bumper??? What are the cnaches of both fogs getting fucked at the same time tho....
H-T White Ops
Re: (vtecftw)
My problem was inside the housing. Should I have wrapped them in electrical tape? I did silicone the entire front edge up (DEPO glass comes off the housing, unlike Esuse glass, which is permanently fastened to the housing), but they still filled with water.
I'm not the only one who has had repeated problems with DEPO foglights. So far all the issues I've heard about have been made by DEPO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">
I got a 97, so it was your grounds??</TD></TR></TABLE>
yes sir jus the ground for me....btw it went out last night..damn it ahahahhahah im goin to rewire the whole thing..
