LS VTEC question
LS VTEC question
i have a LS vtec in my hatch right now and the headgasket went out on me. the block is a B18A1 and the head is an 89 JDM B16. i was just wondering which headgasket am i suppose to use. thanks in advance and sorry i am new to honda-tech.
Re: LS VTEC question (turb0hatch04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb0hatch04 »</TD></TR><TR><TD CLASS="quote">i have a LS vtec in my hatch right now and the headgasket went out on me. the block is a B18A1 and the head is an 89 JDM B16. i was just wondering which headgasket am i suppose to use. thanks in advance and sorry i am new to honda-tech. </TD></TR></TABLE>
if my memory serves me correctly.....you need a headgasket for a b18a1...
Re: LS VTEC question (doood)
it depends on what lsvtec kit you have. if you have the golden eagle kit, then you need a vtec head gasket. if your head is drilled and tapped for lsvtec, then you use a LS head gasket. all LS head gaskets are the same
thanks. yea my head is drilled and tapped so im guessin just use the LS headgasket. i was gonna pull the head out today but the damn weather here is crappy and it started raining so i couldnt pull it out and match it. but thanks all for your response and i will get back to you guys once i put it on. thanks
ok so while i was loosening the head bolts i found out that the top 4 intake side where loose and i didnt have to use a breaker bar to loosen them, so when i was goin to put the head back on and torque the bolts, the intake side threads where stripped, i started with torquing down to 25 ft. lbs. so how would i get this fixed, should i use helicoil on them or what? thanks in advance
cute little bastard
Re: (turb0hatch04)
