have a coulpe swap questions (d16y8 w/ p28)
i am swaping a d16y8 into my 92 civic dx
i am going to use a p28 ecu but was woundering if i need to wire in a knock sensor along with the two v-tec plugs.
Re: have a coulpe swap questions (eg8tuner)
p28 wont have a knock sensor....just leave the knock sensor unhooked thats what I did.....obd1 alternater, intake, dizzy plugs, etc...
Re: have a coulpe swap questions (jesimmers)
sweet thx dude
i am planning on useing my stock harness plus the vtec harness i got off ebay
http://cgi.ebay.com/ebaymotors...d=1,1
any other sugestions
You are going to have to repin your distributor plug(s) to use the ob2 dizzy, the obd1 wont bolt up.....very simple just search for pinouts on here
Use a D15B7 distributor on ur Y8 trust me I did the swap to my 92 Civic LX. Then run ur OBD1 Harness ( YOU ARE gonna have some plugs not plugged) Car will run fine with no CEL if using P28
Re: (92EG8)
thx i was planning on useing my dizzy is my altanator and p/s going to bolt up to the engine also. i am planning on useing this swap to remove the a/c
Re: (95jeremie)
i live in maine it gets to 100 Degrees like twice a year so there realy is no point for losing the 5hp and weight in my auto-x car.
also witch injectors should i use and if i have to switch are they going to fit properly.
Frcfedintegra
04-26-2003 05:05 PM
MEANB18
01-30-2003 03:29 PM
