Sway Bars
Sway Bars
Alright guys, i tried searching "sway bars" but nothing came up so here it goes.
I want to get sway bars. The question is .. is it neccessary to get LCA? or will the stock one not fit the 23mm? thanks guys!
Re: Sway Bars (beebeecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beebeecivic »</TD></TR><TR><TD CLASS="quote">Alright guys, i tried searching "sway bars" but nothing came up so here it goes.
I want to get sway bars. The question is .. is it neccessary to get LCA? or will the stock one not fit the 23mm? thanks guys!</TD></TR></TABLE>
if you have a 92-95 civic that did not come with a sway bar (front or rear) chances are you need to replace the LCA.
you can pick up the front and rears LCA's off of any 92-95 civic ex/si models, or any 94-01 integra. oem ones will do fine, unless you like the bling and pick up some aftermarket ones.
Re: Sway Bars (philosofy1)
what is the car going to be used for? dd, autox, drag?
and why do you even want sway bars?
i would invest my money in good suspension setup
Re: Sway Bars (richard7968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 »</TD></TR><TR><TD CLASS="quote">what is the car going to be used for? dd, autox, drag?
i would invest my money in good suspension setup </TD></TR></TABLE>
Err, a bigger sway bar is part of a suspension setup last time I checked.
Sway bars will help the car out noticably. Make sure to get the asr subframe kit so you do not damage your subframe. I believe your lca's will have the extra holes for the sway bar.
Unceasing Measure
Re: Sway Bars (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You're a liar, beeeeeyotch! »</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for sway bars returned 31 results.</TD></TR></TABLE>
Re: Sway Bars (Archidictus)
I think i was searching the wrong thing.. i was searching at the 92-00 but anyways.. I want the car for partial Track use.. thats the reason why i want the sway bars. Also I dont want the SI one.. if i get the SI one i dont need the Frame brace but if go with the fatty 23mm then i do.. Im jus afraid if i was installing the sway and the endlinks dont connect wit the LCA then im screwed! but yea thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beebeecivic »</TD></TR><TR><TD CLASS="quote">I think i was searching the wrong thing.. i was searching at the 92-00 but anyways.. I want the car for partial Track use.. thats the reason why i want the sway bars. Also I dont want the SI one.. if i get the SI one i dont need the Frame brace but if go with the fatty 23mm then i do.. Im jus afraid if i was installing the sway and the endlinks dont connect wit the LCA then im screwed! but yea thanks! </TD></TR></TABLE>
They will as long as you use the 99-00 civic si links or I think ones from a CRV. I am using 99-00 endlinks with mine and its perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">They will as long as you use the 99-00 civic si links or I think ones from a CRV. I am using 99-00 endlinks with mine and its perfect.</TD></TR></TABLE>
Thanks Bro! so my stockie one has it the holes for the end links correct?
Sway bars will help the car out noticably. Make sure to get the asr subframe kit so you do not damage your subframe. I believe your lca's will have the extra holes for the sway bar.</TD></TR></TABLE>
god i love this forum! and comments like this
ok the only thing i agree with what you said is the ASR subframe kit
IF i were to put a sway bar on my setup regardless of what i was going to use the car for i would only run on the rear WHY you ask to get rid of understeer!
NOW having said that my honda tec friend cambopheonix56 said "Err, a bigger sway bar is part of a suspension setup last time I checked. "
God were do i start with such a comment sway bars are nothing more then dead weight and a waste of time IF you have a good suspension setup that’s fully adjustable such as function form (sure everyone knows who they are?) you can tune the suspension for your driving style and makes sway bar/anti roll bars useless
The only reason manufacturers put sway bars on cars is to increase under steer for the average a to b driver
i hope you understand what i am trying to say if not i guess i will have to go into a big long winded explanation
Si Arn
49
05-03-2004 09:59 PM
