help!! wiring problem smoke coming out!!
* B A N N E D *
well today i was driving my car like normal and when i got home my car started to smoke.. i open the hood to fine out that the box fuse has smoke coming out and my radio shut off.. well when i looked at it the 7.5 backup fuse is burning and melting so now i need a totally new fuse box.. i took out my radio to also find out that some of the wires are crisp and burnt.. what can be causing this problem?? thanks lmk i really need help~~~!!! the car starts fine and everything works except radio since i took it out.. should i just part out the car? also how much are new dash wires?
* B A N N E D *
holy f*ck i just took out my cluster to fine out i burnt a wire and my harness is pretty much fucked!!.. how much would a harness cost? im talking about the wires that are for the radio and cluster also the wires connected to the engine bay fuse box..
Re: (cambosoup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambosoup »</TD></TR><TR><TD CLASS="quote">holy f*ck i just took out my cluster to fine out i burnt a wire and my harness is pretty much fucked!!.. how much would a harness cost? im talking about the wires that are for the radio and cluster also the wires connected to the engine bay fuse box..</TD></TR></TABLE>
Mucho dinero
32117-SR3-A31 WIRE HARNESS, INSTRUMENT $217.73
32100-SR8-A20 WIRE HARNESS, CABIN $723.86
Mucho dinero
* B A N N E D *
could it be because i didnt screw the ground wire from the rad support to the valve cover? well anyways im trying to salvage the harness but most likely will get a new one.. also is the cabin harness the one for the engine bay fuse box? thanks lmk
* B A N N E D *
hmm thanks for the help guys. you think it can be the radio? because i recetly had a friend install my radio. or can it be bacue im not putting the rubber seals on my headlights you know the one you put after the light bulbs?
