WIRING HELP!!!!!
WIRING HELP!!!!!
i have a 93 civic four door dx. bought the car with fried wiring included new dash harness not intstalled. turns out that harness is a auto, so i put it in anyway, but now i got a couple extra plugs and the car isnt starting. i replaced ecu, engine harness, checked timing checked coil, fuses, spark, fuel, fuel injectors. so i narrowed down the problem to being the injectors arent gettin power.
could this be cause of the new dash harness being automatic and the car being manual??
i also put in that aluminum box that goes on driver side kick panel and no difference.
i think there is a plug that would plug into the gear selector....there are 2 wires i think you have to jump...thats the way my RHD car is...i think it has a auto RHD dash harness...
the top row should be like 5 wires, a blank, 2 wires, a blank and then some more wires...those 2 wires you need to jump those...ill double check mine later
Re: WIRING HELP!!!!! (b16crx88)
Check the yel/blk wire at the pgm-fi relay. You should have power with the ign. on. if not check fuse 12 or 24 if you have srs in the under dash fuse box. And fuse #31 uder hood fuse box. if you have power there then there is an open between the relay and the injectors.
usdm.ehtu
03-17-2007 07:54 PM
