will it fit?
will it fit?
My friend has a crx and I have a good timing belt for a 97 civic hx(d16y8). Will the water pump, tensioner, and timing belt interchange between the 91 honda crx si(non vtec d16) and a 97 honda (d16y8 vtec)?
thanks,
robert
thanks,
robert
Re: will it fit? (hall97civic)
may I ask if they changed anything with the head when they made it v-tec? Or did they make the belt wider possibly?
thanks
thanks
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">It might be as easy as the teeth on the water pump </TD></TR></TABLE>
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I want to say no. It might be as easy as the teeth on the water pump but im 99% sure it wont work straight on. </TD></TR></TABLE>
can you elaborate some more on this? Will the water pump from the 97 civic bolt right up? then the pully would match with the belt? Or are the teeth all together different for the crankshaft/camshaft pully?
Re: (hall97civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic »</TD></TR><TR><TD CLASS="quote">
97 water pump get your self the 96+ t-belt and you should be fine!
Re: (richard7968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 »</TD></TR><TR><TD CLASS="quote">
97 water pump get your self the 96+ t-belt and you should be fine!</TD></TR></TABLE>
so since I have the 97 belt, water pump, and tensioner, it will fit! That's sweet! So what did they change on the water pump that they are different?
Modified by hall97civic at 12:01 PM 5/30/2007
Re: (hall97civic)
come on, somebody has to tell me what the difference in the water pumps were and/or be able to back up richard7968 on the verification that the if I use the belt/water pump/tensioner from a 97 that it will fit on a 91 crx!
Re: (Midori Green)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">the 97 hx doesnt even have the d16y8 engine... the y8 is the ex sohc vtec engine</TD></TR></TABLE>
sorry, my bad, d16y5
Modified by hall97civic at 4:56 PM 5/30/2007
Re: (hall97civic)
From 88-00 the crank gear, and the water pump design is the same. Only difference is that each motor has different teeth for the belt (to flow more water through). Thats why you put the water pump to the timing belt.
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic »</TD></TR><TR><TD CLASS="quote">come on, somebody has to tell me what the difference in the water pumps were and/or be able to back up richard7968 on the verification that the if I use the belt/water pump/tensioner from a 97 that it will fit on a 91 crx!
in answer too this!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">From 88-00 the crank gear, and the water pump design is the same. Only difference is that each motor has different teeth for the belt (to flow more water through). Thats why you put the water pump to the timing belt. </TD></TR></TABLE>
which is what i said now you have 2 people saying the same thing i think it is a sure bet were RIGHT!
in answer too this!
Re: (richard7968)
thanks guys, was just wondering what exactly was different was all. Will get around to that hopefully tomorrow then. I really appreciate it!
thanks,
robert
thanks,
robert
got a problem. Got my friends car apart and counted the number of teeth on the 97 belt and it had 105? and then counted the crx's and it had 108? and the water pump both have 15. So should it still work? the gears look different for the camshafts(I just did my 97, that's why I have an extra one). What do you think guys, do I need to order a new one or should I mark the spots on the cam with a paint marker onto the timing belt and sping the engine over 4 times and see if the marks line up or should the marks line up every full revolution?
SlammedDC2
06-11-2007 07:53 PM
cxjon
06-19-2005 07:08 AM
hondaowner
04-06-2005 09:32 AM
