b18c1 valve cover modification
I want to put the moons in my valve cover for my cam gears, but i dont wanna mess it up. wat would be the best do it yourself way to go about it?
HT White Ops
Re: (boost-em-now)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost-em-now »</TD></TR><TR><TD CLASS="quote">it would crack or chip the paint around the cuts?</TD></TR></TABLE>
It's a distinct possibility. That's why you use something nice and sharp.
Darth ModerVader
Re: b18c1 valve cover modification (boost-em-now)
I'd suggest picking up a cheap used valve cover for tuning. You can hack it up all you want, install it while tuning, and then re-install your original one after you're finished. You'll be guaranteed not to damage yours, and you'll also eliminate the possibility of any debris making its way into the timing belt area through the cut-outs.
HT White Ops
Re: b18c1 valve cover modification (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I'd suggest picking up a cheap used valve cover for tuning. You can hack it up all you want, install it while tuning, and then re-install your original one after you're finished. You'll be guaranteed not to damage yours, and you'll also eliminate the possibility of any debris making its way into the timing belt area through the cut-outs. </TD></TR></TABLE>
A much better suggestion than mine. Granted, I would never cut my daily valve cover.
