should i get a JDM D15 or a D16z6... i've searched
is it true rods are expensive for the 1.5?
i dont know why it's so hard to decide for a DD...
btw i will be ordering with a matching transmission. CX ftl..!!!!!
Re: should i get a JDM D15 or a D16z6... i've searched (allricedout)
I'd go with the Z6, as one should be availably semi-locally. With all the hype surrounding the D15B, the Z6 might be cheaper.
Re: should i get a JDM D15 or a D16z6... i've searched (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">I'd go with the Z6, as one should be availably semi-locally. With all the hype surrounding the D15B, the Z6 might be cheaper.</TD></TR></TABLE>
im not sure how much the Z6's go for locally but i am planning on ordering from http://www.hmotorsonline.com anyways. the JDM D15 with transmission and ecu will be 800 before shipping.... and the Z6 swap from them?.... let me check
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">I can probably find a full D16Z6 swap for half of that (or atleast very close to it).</TD></TR></TABLE>
x2,dont pay a grand for a D series.H motors is good for everything else other than Ds
if you can get a z6 i would go for that...you should be able to get it cheaper then 800
another thing is z6 has way more readily available parts...
if you ever want to build your d15 for turbo well you cant unless you custom order alot of stuff.
z6.
z6.
Re: should i get a JDM D15 or a D16z6... i've searched (Felliph3)
hmo doesnt sell the Z6 i dont know why.
Modified by allricedout at 4:26 PM 5/27/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">hmo doesnt sell the Z6 i dont know why.
Modified by allricedout at 4:26 PM 5/27/2007</TD></TR></TABLE>
they only really sell jdm motors...
just a suggestion you might want to give these guy's a call
i purchased a D16Z6 from them for 575. and i believe it was either 150 or 175 delivery to the house garage door . really great guy's bent over backwards to provide a TPS that got broke in transport
http://www.soshinusa.com/default2.asp
Re: should i get a JDM D15 or a D16z6... i've searched (alchem)
D15B has 3 stage vtec,great power while still staying economic. The z6s are more plentyful so if you blow a hole in ur block,no prob. just get another one for 300!
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">I have the JDM D15b
VTEC hits as loud (sometimes louder) than most stock Dual cam motors that any of my friends have</TD></TR></TABLE>
that shouldnt even be a reason to get a motor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 »</TD></TR><TR><TD CLASS="quote">D15B has 3 stage vtec,great power while still staying economic. The z6s are more plentyful so if you blow a hole in ur block,no prob. just get another one for 300!</TD></TR></TABLE>
no sir your thinking of a different model. This one is only two stages...the one your thinking of is a different model which no one really swaps.
WOW!!! Lots of bullshit information flying arround here....
I purchased a D15b from H motors last week and it will be here any day now.
First of all a D15B isnt hard to turbo at all!! It's a D series for expletive sake!! Exhaust and intake **** is all the same. You can get rods and pistons for it with no problem too. finding spare parts for it is easy too i.e. water pump, gaskets and ****...Just do your reseach for the right aplication.
Secondly......It's not a 3 stage Vtec. There are some that were stage 3 Vtec but they're not a desierable motor.
Go here.....YOU'LL LEARN A TON!!! http://www.d-series.org/forums...32597
Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote"> You can get rods and pistons for it with no problem too. </TD></TR></TABLE>
no sir you cant...you need custom rods
i have the z6 in my ej. awsome high end power with an igntion upgrade header exaust and cai. plus its easy to find parts. theyre cheap. you only have to buy on cam if you upgrade that. hell a greddy tubo kit its only $1500 from nopi. and another $600 for a fmic. ud have way less trouble droppin in a z6 in my opinion b/c you can find parts easy here. new or used.
Re: should i get a JDM D15 or a D16z6... i've searched (DCSportEJ1Civic)
[Shameless plug]D16Z6 is awesome, I also happen to be selling one [/Shameless plug]
Guest
Posts: n/a
Re: should i get a JDM D15 or a D16z6... i've searched (Ep1dem1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep1dem1c »</TD></TR><TR><TD CLASS="quote">B-Series... you wont regret it</TD></TR></TABLE>
yea i'm sure he'll love spending 3 grand on a 15 second daily driver
anyways, you can get a z6 swap for 400 easy, http://www.carparts.com, searchs junkyards all over the us. I picked up a complete z6 with tranny for 550, got anther z6 for 350, and a y8 for 400.
Re: should i get a JDM D15 or a D16z6... i've searched (GarageAlchemist)
Thres 2 d15bs,how the hell do u want me to figure out which one?
[edit] D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
[edit] D15B (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.6:1
Fuel Control : OBD-2 MPFI
[edit] D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 »</TD></TR><TR><TD CLASS="quote">Thres 2 d15bs,how the hell do u want me to figure out which one?
[edit] D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
you dont have too...the 3 stage vtec is not widely available and NO ONE(im sure some douche did but 99% dont) swaps it in their car.
almost everyone i know who swapped in a B16 regreted it and wish they either just went SOHC turbo or LS turbo or saved for a b18c or c5 since the b16 cost so much and has so little power...
[edit] D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
Ek Forever y0!
Re: should i get a JDM D15 or a D16z6... i've searched (The Lobster)
Where are you buying it from and how much will it cost?
Because I bet for an extra $300-500 you can get a b18b.
Re: should i get a JDM D15 or a D16z6... i've searched (ek forever guy)
you should be able to get a b18a/b installed for like 1500 full swap... atleast a few people where i live do it for that much. That includes everything from motor to tranny all mounts and everything
