Problems with Tein Basic Suspension
Old May 27, 2007 | 11:31 AM
4thgenx42's Avatar
Default Problems with Tein Basic Suspension
Well today I attempted to lower my car again for the summer. I ran into a huge problem. The locking nut (bottom one) unlocks and moves freely but the top one doesnt. It wouldnt budge for anything in the world. Even using a breaker bar couldnt budge this thing.
Has anyone ran into this problem before? If so how did you correct it? Any ideas?
Thanks for your help!
Old May 27, 2007 | 11:40 AM
Crasian's Avatar
impact gun
Old May 27, 2007 | 07:43 PM
4thgenx42's Avatar
Default Re: (Crasian)
How an impact gun goint to loosen my coilovers? Its stuck at the piece where you twist to adjust the ride height.
Old May 27, 2007 | 07:45 PM
97Ej6mike's Avatar
Sounds like its siezed, Use lots of wd40 and/or PB blaster ( works great), and some heat wouldnt hurt too, take a torch to it for a very small amount of time, just enough to heat it up. If you presoak it in ANti-seize spray ( PB blaster or WD40), let it soak for 10 mins, then heat it up with the torch, that should do the trick to freeing it up.
Old May 28, 2007 | 12:20 AM
lilo_goki's Avatar
spray it with wd40 and let it sit for a while then u should be able to turn it..i have tein basics and mine are fine..urs are probably rusty and it probably collects dust.
cJ_EG2
Suspension & Brakes
Apr 26, 2006 04:28 AM
NATURAL ASPIRATI0N
Mar 15, 2004 11:46 AM
daewonder.
Jan 23, 2004 05:51 PM
ITR_1211
Dec 25, 2003 09:11 PM
hohiah
Aug 23, 2002 10:38 PM
