radiator filling up with oil
So i had got my engine back from machine shop that they had a assembled b18c1 i put the head gasket from golden eagle on and my b16 head once the engine was put into my vehicle i started it up not even 5 seconds of it being started i noticed oil ouring out of my radiator does anyone know what that could be. thanks for your time
I'm not Rick!
Re: radiator filling up with oil
you have a numnut put oil in the radiator before you started it?
if you ahve oil in radiator *coming from the motor* you would have coolant in the oil also, mixing.
drain it. refill it. try again
No one put oil in my radiator when my son start d my v Hicks after installation of engine oil filled my top radiator hose causing it to fill up my radiator that was the first and last time the engine has been started
Fish Twig
unless someone poured a quart of oil into the radiator I suggest you check that headgasket installation. If you do plan to check the headgasket drain everything and inspect the coolant passage way.
KeEpxiTxLiTt
11-19-2007 10:45 AM
GsrTurboCRX88
05-02-2007 05:36 PM
ujhonda
05-28-2006 08:16 PM
