Turbo d16y8 with vitaras sheared the cam key
Cam key broke and I put a new gear on it but now the car is running super rich at idle 11.5-12.0. Before it broke it would idle at 14.5-14.7. I pulled the ecu fuse could it have something to do with that? Like idle learn causing the rich condition thanks
Re: Turbo d16y8 with vitaras sheared the cam key
The cam key is machined into the gear itself on the Y8... did you have a stock gear before and after ???
I checked the alignment of the belt guess I need to pull the crank pulley and check the mark behind the timing cover
sbk23
12-21-2009 09:13 PM
trooper0641
06-04-2004 10:05 AM
