Need help 98 Ek hatch with a b20motor
I have a few ? I have a 98 Ek hatch doing a b20 high compression with a b16 tran and a skunk two mani with 70 matching tb with a stage 3 clutch and 10 lb flywheel and beside that motor stock but all the parts new axle and shift link and etc but my ? Is how is this step up and will it run good and anyone would know how much hp will it have and how high would my rpm be in five gear going about 70 and this step up for now onto I put my gsr head on but building the head so can’t at the moment and Thsnxk for everyone help
Fish Twig
Re: Need help 98 Ek hatch with a b20motor
Step up from what?
Will it run good against what?
Why would the hp be any different?
Shouldn't rev be the same as what it was in its original car?
No rev wouldn’t be the same cause this Ek come with single cam motor if you didn’t know rev wouldn’t be the same cause it’s a B16 tran if yiu didn’t know that I don’t know why you on here rev not the same and I just ask how would it run not against anyone just wanted to know if it will push alot better then a single cam
Fish Twig
If I understood everything you were asking correctly, kind of hard to follow.
-Compared to the stock single cam, the b20 will look/feel like a beast. Still not a power house, but the additional torque and hp will make the car a lot more fun to drive.
-Your hp/whp will more than likely be what the engine was stock, your bolt ons you listed really won't gain you much without other supporting mods, such as a tune, cams, exhaust, etc...Once you throw a vtec cylinder head on it & once again get an appropriate tune it will really wake it up.
-Assuming your b16 transmission is from USDM car, example: 99-00 Civic Si, and your tire height is similar to the 195/55/r15 that car came with, your rpms at 70mph should be approx 4k.
-Your rev limit as the b20 sits now should be whatever it is stock, I am not sure what ecu you are running or planning on running. But if it is a stock ecu, then you are limited to whatever the factory rev limit is and what the stock bottom end can handle.
