ek9 cluster gas gauge wrong?
i have a 2000 civic and i just swapped out my cluster for an ek9 .. everything works except the gas reading is way lower then my stock one.. has anyone experienced this?
Re: ek9 cluster gas gauge wrong?
Honda service manual, basically gotta unplug the harness on the tank side and short 2 wires (Cant remember which ones) turn the key to ignition (dont start the car) then the gas needle will slowly rise and once it reaches full turn the key off. Make sure you fill up the tank.
Also the 2 wires that short if you take your multimeter it should read between 5v-8v with the key on. If either of these techniques do not work then you will have to replace the fuel/temp gauge in the cluster.
Hiroshima_VTi-S
05-30-2007 10:35 PM
