B16 engine and stock honda transmission
Old 11-25-2009, 04:28 PM
New User
hondapower94's Avatar
Default B16 engine and stock honda transmission
I am putting a new engine into my 94 civic lx and I was thinking of putting a b16 in it but I dont know if a stock honda transmission will work with the acura engine even though they are from the same company. Any advice would be appreciated. Thanks.
Old 11-25-2009, 04:37 PM
FearTheH's Avatar
Default Re: B16 engine and stock honda transmission
B16 is from a honda. And you have to have a B series transmission, searh here and google for b16 swap. Its a lot of work, you will need to swap the motor, transmission, axles, ECU, wiring harness and get a mount kit to do this. And welcome to HT
Old 11-25-2009, 04:43 PM
Matt93eg's Avatar
B-Series Engine goes with B-Series Tranny. D-Series Engine goes with D-Series tranny so if by "Stock Transmission" you mean your D-Series tranny then the answer is no and you will need to get the things FeartheH said. I would start doing PLENTY of research if I were you before starting any kind of swap.
Old 11-25-2009, 07:17 PM
New User
Thanks. Im new to all the import stuff and Im used to the good old chevy 350 so I need to learn a couple things.
Old 11-25-2009, 07:20 PM
Matt93eg's Avatar
Hey, everyone has to learn. I still learn . Its just better to research stuff over and over again and get the right parts the first time and do the labor right the first time, it gets more expensive having to do things over again that could have been avoided.
Old 11-25-2009, 07:38 PM
New User
So going by matt's explanation i can get a little bit more horsepower with the d16 and itll still bolt right in without too much hassle, right?
Old 11-25-2009, 08:01 PM
DAintegraGSR's Avatar
which are you thinking of eventually swaping in?
B16 or D16
original post said B16 but yea it could be done with verry little hassel a few parts and some know how.
a D16 can be very easily swapped in to your car with hardly any part beside the motor.
but yea definetly start abusing the search engine gotta lot to learn and welcome to the Honda World
readyjetsgo
10-05-2014 03:14 PM
loveformycivic
14
09-08-2013 01:37 PM
tek_civic
02-04-2004 02:12 PM
Quick Reply: B16 engine and stock honda transmission
