92 Gsr Hatch Wont Rev Past 3k
i have a 92 eg hatch with b18c1,hondata s200,ect. i was getting into it and it bogged out, it didnt die but it wouldnt let me go past 3k and it was sputtering and stuff .. the timing didnt jump and i dunno whats up with it .. i had it back to normal just messing with random **** and then shut it off and then it was doing the same thing .. what could this be
Re: 92 Gsr Hatch Wont Rev Past 3k
Any codes? I started a thread about this same thing last night. Possibly crankshaft position sensor, ronj@ht told me to check distributor harness wiring... Check yours. Could also be the actual sensor in the distributor housing, but without any codes no one will be able to help much. Pull codes and let us know what she says.
cam or Crank sensor might cause this. also check the grounds on the engine and re-clean and ground everything.
just my $.02
just my $.02
i gave up on it for today ...ive tried almost everything i could
-Completly Retimed Engine (tdc.up+up.ect.)
-Changed Dizzy
-Tried Stock Gsr ECU
and still same thing as before ... any more ideas
this thing i dont get it before i changed any of that if i would mess with little stuff and let it run for couple mins it would start being normal again well i would shut it off and it would go back to doing the same damn thing as before... any more ideas of what it could be ..
How do i check my icm and map .. and yes i do have cels but they have been on since i got the car ..
Uggghhhhhhhh im so lost
-Changed Dizzy
you got me i was gonna say try a diff gsr ecu, but i guess you already did that... hmmm idk then, what else have you tried?
sounds like limp mode.. do you have a knock sensor not grounded all the way, or interference with the dizzy wires if they were cut..
My friend had this same issue on his gsr swap an all it was was his tps and some other sensor with the same style clip were backwards, look into that.
