Are these two plugs interchangeable?
I have a tuck harness the the guys @ Rywire made for me, and I was thinking for a second that they didn't install a plug. Now I'm thinking that I was wrong to think that. They make many of these harnesses and I just don't see how they would mess up on something like that. I was thinking; since I'm using a bunch of parts that were laying around from a few builds, that I may have a couple of sensors that do the same thing here. Spacificly the thermostat housing sensor and the sensor in the head. Are they for the same readings or not? Can I just delete(not use) the one in the head? Because there is no plug for that sensor on this part of the harness, and I have every other plug figured out. I hope that there is someone that can answer this question definitively. Here is some pics for reference.
Here is the one in the thermostat housing:
And the one for the head: KEEP IN MIND THAT IT'S THE ONE WITH THE CLIP ON IT(BOTTOM) DO I SWITCH THE CLIP FROM THE BOTTOM SENSOR TO THE V-TEC PRESSURE SWITCH?
Just for good measure, here is one of both of them.
Technical Hero
Re: Are these two plugs interchangeable?
they are not interchangeable or deletable, one sends the signal for the fan to come on at a determined temperature and one sends signal to the ECU on water temperature (TW) to determine lean/rich mixture adjusts.
So I also found this on Rywire's site. They don't have an oil pressure switch either. Is there a way to bypass this. What the hell is going on here. I AM SO CONFUSED!
Correct, the JDM solenoid does not have the oil switch at all. It really depends on what ecu you are running. If its a stock ecu for the motor then you are going to want to run it. If its an aftermarket tuneable ecu you could have your tuner disable it.
Sweet **** guys. I didn't think Rywire would just miss something like that. I really appreciate the help guys!
