Thanksgiving emergancy!! EG died need help FAST!!!
OK boys, I have been a guest here for about a year after being referred to you all by a mechanic friend. I have seen alot of very sound advice given out and now I am finally a registered member, on my second Civic, and badly in need of your sound advice. Tuesday night on the way home my baby EG died while going about 65mph, I figured timing belt broke heads screwed anyways so I tried to kick it over and it started!! I got her about 20ft. some @$$hole hit his brakes so I did as well and she died again. I replaced my fuel filter, checked my fuel pump(working fine), checked my thermostat, checked all my s. plugs, going to check my distributor when I'm done posting this. She will start up after about 3-4 turns of the key and will hold a steady idle for around 10min. then just quietly die again(no shaking no sputtering just shuts off). Oh, one last thing I noticed is that my cooling fans(both) are not activating, and neither my upper or lower radiator hoses have any pressure behind them but both hoses get hot like they have fluid moving through them. So as you can see I am completely stumped, I am a courier and this happened Tuesday night, if I cant get her running by Friday morning I'm out of a job. I'm in panic mode guys throw your ideas at me, I'll be watching my post while I'm tearing her apart today, theres alot of knowledge in this community and I know you guys will help, thanks, and HAPPY HOLIDAYS TO ALL YOU HONDA NUTS!!!!!
Re: Thanksgiving emergancy!! EG died need help FAST!!!
Hrmm, if you've done all that I'm at a loss. definitely check your distributor out and check/clean all your grounds. Hopefully someone more knowledgeable could chime in. Is your car throwing any codes?
have a buddy coming over later to scan it, but its OBD1 right? OBD1 cant shut down my engine if i remember correctly.
check the codes yourself, jump the plug and count the flashes. There's a thread on how to do it with codes at the top of the page.
Wow, great post on how to check codes, waiting on tow truck to get her to my house, maybe another 30min. then thats the first thing I'm doing, I had no idea I could do that myself. Oh and I replaced the FF first thing yesterday morning.
pulled my own code and the cel just stays lit does not flash at all, I am stumped, guess im screwed i really dont know what to do next
did you have any codes to begin with? and it will stay lit when you turn the car over but if you just turn it to the on position it will flash. pull the plugs and see what they look like.
Ignition module going?, i would say main relay but that usually causes it to not start
ok, swapped relay for rear defoger to relay for cooling fans and it worked, fans kicked on, drove it around the block and it seemed fine, still scared, im gonna drive it to autozone and grab an ignition module, thanks for all the help guys will keep u posted.
Feb. 2010 B16 swap!!!
Ok, finally got Ignition Control tested...FAILED BOTH LOW AND HIGH RPM TEST, thank you all for the help, helps me think when I can throw ideas around with other knowledgeable people. Honda-Tech just saved my ***(and my job). Really guys, again, thank you and happy holidays
**** **** ****, got it all the way to work, taking a delivery up US75 north going 65mph car died. Thing is now, it wont start up at all will kick over just wont stay running, not getting any lights at all on cluster, tried to pull my codes again and nothing, she is dead.
I replaced wires plugs Ignition control module fuel filter checked tensioner pulley. WTF WTF WTF. I am completely stumped.
Sounds like your fuel pump. This was happening to me on a TRE pump that I had in there for about 5k. Do you have a fuel gauge? Do you know if your getting fuel?
You are getting no lights on the cluster at all? If so your ECU might be dead. But im betting on either ECU or Fuel pump or main relay. When you turn the key to On(II) do you hear the fuel pump prime? Does it sound like its dry or make a loud whining noise?
fuel pump good, whn i pulled code light only on steady whn wire was in, yes I can hear fuel pump priming line, 3/4 tank of gas so wht that means is I need to take my ECU to honda an have it tested, right?
The ECU is the last item to consider.
Check for spark at the plugs. If you have spark, it should be bright white.
If spark is fine, check whether the timing belt skipped some teeth.
Figured it out, i am gonna post pics tonight of this crazy ****, I couldnt belive my eyes when I saw what I saw. My EG was stolen from the previous owners(I am only 2nd owner!!), they told me they replaced the ignition assembly when they got it back. So at 1am I am pissed at this car so I start running all the wiring looking for the problem, I get to the driver side dash and lo and behold the 2nd ignition switch that was spliced in and used to steal the car WAS LEFT WIRED IN AND TUCKED ON TOP OF THE STEERING!!!! Every time I turned the wheel or hit a bump, or whatever it tripped the wiring and shut my car down, eventually it got stuck right between on and off. I am still astonished, flabergasted, amazed, shocked, or whatever other word you can think of. It took me working on that car till 1am and getting beyond pissed to find that, never in a million years would I have thought that was the problem. So thank you all again for your help, oh and yes my ECU was fried, my Ignition control was fried, and my fuel filter was trash so you all did advise me correctly, those were problems, just not the last problem. Thanks again!
smichka
04-09-2014 03:26 PM
bakomack
01-26-2011 04:38 PM
stunt1048
11
03-18-2010 12:02 AM
civicracer94
12-01-2005 04:47 AM
