K20Z3 swap in EK. HELP!
Old 11-23-2009, 07:21 PM
FRKWOO's Avatar
Default K20Z3 swap in EK. HELP!
about to pick up a 07 civic si k20z3 complete swap of craigslist for $2200.00. the owner of the swap claims i would need rsx k20 throttle body, wire harness, ecu because the k20z3 doesnt use a throttle cable. is this true and will i have change anything else on the z3 to run it in my ek? thanks
Old 11-23-2009, 07:35 PM
Jdmglenn's Avatar
Default Re: K20Z3 swap in EK. HELP!
it prob has the fly by wire like the newer s2000's. Uses a magnet on the top the the gas pedal instead of a throttle cable
Old 11-23-2009, 07:43 PM
FRKWOO's Avatar
probably the same, so how would i be able to do it? like he said rsx type r tb with wire harness and ecu???
Old 11-23-2009, 09:30 PM
FRKWOO's Avatar
ttt
Old 11-24-2009, 10:31 AM
FRKWOO's Avatar
ttt
Old 11-24-2009, 10:41 AM
jdmeg2808's Avatar
yes you will need the 04 rsx throttle body, the rsx wire harness, and a k-pro to make it work. Also you will need to get a rsx shift box and the cables, and the shifting mechanism on the trans if you want to have a clean swap. other wise the z3 shift box will be exposed on the ek without a center console since the z3 shift box is tooo bulky. but you cannot jus get an rsx shift box. you'll need the cables and the shifting mechanism. its a trip to put a z3 in an ek. plus dont forget all the other parts you'll need to put it in the car... If your willing to spend $2200 it's better to just build a D or swap a B in the car. But thats just my opinion. I hope this was helpful.
JDM_Dream
Honda Civic (2006 - 2015)
10
12-22-2009 02:56 AM
BoltonGSR
18
12-10-2008 05:02 PM
Thumpinmonk3y
67
04-06-2008 03:31 PM
SoullessJapaneseMachine
11-06-2007 03:53 PM
Quick Reply: K20Z3 swap in EK. HELP!
