Ignition switch going bad?
my 94 civic dx will randomly cut off when driving when it does this my clock shut off my clock and dash idiot lights cut off and the gauges drop to zero expect fuel of couse but the radio keeps playing as if the key is in accessory after it does this when i turn the key to start the normal dash lights come on as if the car is starting but the starter doesnt even crank to start it i have to turn the igintion to off and take the key out then put it back in and it will start up normally pls help me fix her could it be the ignition switch possibly idk pls help
Re: possible ignition switch going bad
i got the same exact problem, and i just order a brand new ignition switch!!! hope it will fix my problem!! also check if your main relay make 2 click when going into 3rd position with your key may be its your problem...
good luck
good luck
allsho
02-10-2007 05:05 PM
