how do you make a vx lean burn all the time?
just play'in around for kicks to see what the mpg's would be if in lean burn all the time(3 valve mode) and not in lean burn(4 valve mode)? Is this easy enough to do without gettin to crazy of a mod? Right now I just have the wire from the spool valve pulled and it feels like its in not in lean burn but won't know till I check my mileage. Like I say just for kicks to see what mpg's are? Anyone every tried this?
Oh look, I can change this
Re: how do you make a vx lean burn all the time?
You need to research this to learn that lean burn at the wrong RPMs doesn't improve gas mileage / fuel economy.
Your homework, READ: http://www.gassavers.org/showthread.php?t=2427
Im sure Honda does this on purpose and messing with the valves and fuel flow will lead to larger issues later on.
So I take it no ones ever done this or tried it? With the spool valve plug pulled she runs with both intake vales all the time and runs very nice I might add but mpgs are around 40. Can't figure how to make her run on one intake valve all the time?
