94 del sol/B16 with 165-175 psi cylinder compressions - Is this good?
So I have a 94 del sol with a b-16 and just did a compression test. It came up between 165 and 175 psi. The motor has 243 thousand miles. Is that good compression or what?
Re: 94 del sol/B16 with 165-175 psi cylinder compressions - Is this good?
It gives you an accurate reading plus it fills the cylinders much faster . The last thing you want is numbers all over the place. It is the PROPER way of doing a compression test.
The throttle angle directly affects the cylinder pressure when the intake valves close, so it'll affect your cranking pressure too.
The engine was warm I did the cylinder closest to the distributor first it was 175 second was 173 third was 168 and 4th was 165.
luvmihatch
14
02-05-2011 09:43 PM
cleaned throttle body on '94 del sol S, now my gas mileage kinda sucks and hydrocarbon output is out
Neptronix
02-01-2008 11:11 AM
ShagNastyEK9
05-23-2007 05:44 PM
prodigalson
07-23-2004 04:49 PM
