EG pre-purchase inspection checklist?
Tried to search... if there's an existing thread, please link!
I'm looking at a 93 VX, and was wondering if there is anything Civic-specific I should look for when buying. It has the D15Z1 engine, which I will be keeping.
I've only had one Civic, so I'm not as familiar with the common issues or failures.
Re: EG pre-purchase inspection checklist?
any leaks, core support, how it drives.
Has the timing belt, water pump been dont, if so when?
Brakes, accidents, clean title,rust on 1/4 pannels?
Im sure others will be able to add more.
the main things you need to worry about keeping your car running are the brakes rotors master cylinder timing belt water pump and clutch. those are realatively easy fixes but will cost you more down the line if they fail on you.
if you dont know anybody who works on hondas just ask around. im sure your town has somebody.just try to avoid the whole mechanic/dealer thing for these fixes. they will cost the same as your car
talks to himself
check for rust around the seat bracket bolts. also check for busted engine mounts. Check for milky coolant. my exhaust fell off around 190k...
As kyosoeg6 suggests check your brake pads, resurface your brake rotors, change your timing belt and your water pump. cheap and easy.
animated_life
10-22-2002 09:48 PM
belt, buying, car, cars, checklist, civic, honda, inspection, pre, prepurchase, purchase, timing, tips, vancouver, washington
