96 Civic coupe - Parking lights fuse keeps blowing
96 civic coupe b series
Hey ht i have a problem with my fuse shorting out for my parking lights, corner light, and license plate fuse for some reason as soon as i turn on the switch the fuse goes out. I dont know whats causing this but i really need it fixed so i can drive at night or else my tail lights wont work so someone please help it would be appreciated thanks. Also more info its supposed to be a 7.5 fuse and ive put a 20 fuse when i tried it if i need a 7.5 then ill go buy one but idk if thats whats causing it or not.
Re: Fuse keeps shorting out
Don't install a higher amp fuse. It's a fire hazard and may lead to expensive wire damage.
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
no the only thing ive done is connect a aftermarket radio and im starting to think its shorting something out in there i will go take a look now and see if anything is touching
Re: 96 Civic coupe - Parking lights fuse keeps blowing
im having the same problem on my 2000 civic coupe... only thing i did was add another ground to the radio harness because the radio would turn off with the brakes...
stupidasso15
16
03-15-2012 09:07 PM
crazydrew
10-23-2007 12:33 PM
skyvang2
05-28-2007 03:21 PM
