B18b swapped 92 hatch with CEL codes 10, 21, & 41 and also low mpg
so i just bought a b18b swaped 92 vx hatch and it idles like crap and running rich as all hell...i drove for an hour and used half tank of gas...it has check engine light on so i jumped the plug by the ECU and pulled the codes
21= VTEC spool solenoid valve
41= primary oxygen sensor
10= IAT intake air temperature sensor
would fixing 41 and 10 fix my crappy idle and excessive fuel consumption?
and why am i getting a code 21 when its not VTEC?
any help would be greatly apprecieated
thanks
thanks
Seagull Management
Re: B18b swapped 92 hatch with CEL codes 10, 21, & 41 and also low mpg
It addition to what Ron said you might want to see what ECU you have in there. And what was used for an O2 sensor.
Seagull Management
You could also use an OBD1 PR4 ('92 - '93 Integra RS/LS/GS ECU)
Last edited by Former User; 11-15-2010 at 12:42 PM. Reason: Removal of WTB post - just clean up. You did nothing wrong.
ok thanks, i have to see if the one i have is OBD2 or 1, then i can go from there
joes-92
26
03-20-2013 05:17 PM
Twilightepitaph
10-20-2009 08:01 AM
