How do you change the trun lights in a 2002 civic ex
Re: How do you change the trun lights in a 2002 civic ex (Duckrc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duckrc »</TD></TR><TR><TD CLASS="quote">How do you get the front lights off of a 02 civic ex
You mean you want to change the turn signal lights? If I remember correctly, the turn signal lights are mounted within the fender sheetmetal, so the whole light assy. needs to be removed to change it. Take the bumper off, then there should be 4 bolts that hold the light fixture into place.
My first guess is READ THE MANUAL, since it does a pretty good job of explaining how to turn the wheel, remove the clip and screw from the fender well, then peeling it back to give you access to the turn signal and parking light harnesses.
Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">My first guess is READ THE MANUAL, since it does a pretty good job of explaining how to turn the wheel, remove the clip and screw from the fender well, then peeling it back to give you access to the turn signal and parking light harnesses.</TD></TR></TABLE>
Yeah, I forgot about that. When I did someones, we were installing some other stuff too, so we had the bumper off already. Make sure you have more pop rivets for the fenderlining though. Everytime I try to take one off, they break because dirt gets trapped in the back of them, and it's a bish to get them out in one peice.
Tsoccer63
Honda Civic (2001 - 2005)
01-27-2008 12:00 PM
miakae
06-24-2006 11:51 AM
