camber kit question
Re: camber kit question (jerm001)
Once you go under 2" then you will start having camber problems...so usualy a good height is 1.75" all around...I had that with my 17" on my civic and the camber was fine.
Re: (jerm001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerm001 »</TD></TR><TR><TD CLASS="quote">so I should be fine with 15" rims and a 1.75" drop?</TD></TR></TABLE>
On my girlfriend's Civic, she has 15"s with just about that same drop if not higher. Even on her Ingals set-camber, she wears just slightly on the insides.
Re: (TallAssFilipino)
"On my girlfriend's Civic, she has 15"s with just about that same drop if not higher. Even on her Ingals set-camber, she wears just slightly on the insides"
SO your saying I will need a camber kit?
Re: (jerm001)
Well, base on his opinion and on what I've seen, decide between the two. Most importantly, just notice how your tires wear. You should be able to tell.
its kind of a money thing, If I need a camber kit I'll have to wait a while till I get some more money, because I only have enough for rims plus tires, and I already have shocks and coilovers, if I need a camber kit then I'll probably just roll on the stock steelies for a while
