ok clutch is scary....
i finally got some miles on my clutch so i took a fast little test drive on my b16a2 the car is a 00 si and i was wondering my cars jumps in 3rd and almost jumps in
4th im scared im going to break sumthing shifting that hard what can i do so like motor mounts dont go or axles or cv's should i be worried?
the clutch is a act stage 2
1 Post
Re: ok clutch is scary.... (b18c5-EM1)
What do you mean, "jumps"? If you're referring to your clutch grabbing hard and giving you wheel hop, that's normal. You should probably upgrade your mounts if it's bouncing hard, though. Wheel hop is not good for axles...
Re: ok clutch is scary.... (hatchling37)
will new motor mounts stop the wheel hop?
or are u sayin the wheel hop wont be forced upon the axles as much if i get stiffer motor mounts....??
im talking about this thing ****** hops even in 3rd and almost into 4th
If you wanna get rid of wheel hop, get a torque dampner or a traction bar..full race makes them and its like 350$. I would also get stiffer motor mounts as well.
Re: (b18c5-EM1)
Energy suspension makes a kit called the hyperflex set... they're full suspension bushings, they help wheel hop alot, and then motor mount inserts and you should be all set... plus any other traction bars, etc.
Re: (95DXPhiladeph)
i have a b16a2 hatch with an ITR tranny and exedy race clutch... it does the same... the gears grab HARD. Its normal, and get used to it.
B A N N E D
Re: (b18c5-EM1)
Get better axles, like race axles if its as serious as you say. I think you may be over exagerating a little but thats ok to do sometimes but yeah better mounts also
Re: (kaoss_11)
i dont care but i bet im loosin a lot of time on the 1/4 not like my 1/4 miles is fast or anything but i need more grip and it just seems like sumthing is going to break lol
aemintgsr
16
10-21-2013 02:20 AM
Mikes2000civicsi
12-28-2006 08:39 AM
