Dent Oil Pan
Dent Oil Pan
Could this have cause the vtec not to engage anymore because the vtec was working properly and a couple of days ago i hit a rock that dented my oil pan right next to the oil drain bolt and now i dont hear vtec anymore.. Or could it be electrical problems before the rock accident, vtec wants to work it will work and sometime it doesnt..
Electrician
Maybe the dent is causing low oil pressure. When there is low oil pressure, VTEC is not going to engage. If there is not enough oil, VTEC will not engage. Do you have any CELs or any other lights come on? Try removing the oil pan, bash the dented part out and check if that helps. It's probably the problem.
Re: Dent Oil Pan (SilverSI)
if the oil preasure light is not on then i would say that the dent is not the problem, most likely an electrical problem, or you may just be low on oil
Re: Dent Oil Pan (ae_rabbit)
no the oil pressure light is not on and i do have enough oil in my car and maybe if its an electrical problems than does anyone know what part of that electrical problem might be. check wire to ecu is ok and all plugs are plugs. I do have check engine light intition misfire and that only makes me crank my car for a couple of seconds than my car starts. any anwers will help...
sol2hatch
03-06-2006 10:45 AM
ekim952522000
12-12-2005 04:47 PM
