have tranny 1 inch seperated from block but it wont move any farther need help and pics asap
i need to get this thing by tonight help me please i searched but i cant find any pics and i dont want to damage anything
Re: have tranny 1 inch seperated from block but it wont move any farther need help and pics as
Axles have been removed right? Keep trying. Get underneath to push up, and have somebody else pull it away from the motor from above.
Are you just trying to get it off. IF so just wiggle it a little bit. It helps to have two ppl because one can be kind of underneath either prying a little or wiggling the transmission from side to side while also pulling it away from the engine. If you are trying to get the tranny back on the bolts will push everything together just tighten them in order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">i need to get this thing by tonight help me please i searched but i cant find any pics and i dont want to damage anything</TD></TR></TABLE>
On the 2 sides of either the block or the tranny, where the block and tranny meet, there are 2 steel dowel rods that are meant to line up. Make sure those aren't damaged or bent because if they are, that is your problem. That is stopping the tranny from going in flush.
you prolly forgot to remove something
rear tranny mount bolts?
clutch cover?
clutch cover?
thanks guy for the wick response i just got it off i misse one little bolt and it popped right off......haha but thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">thanks guy for the wick response i just got it off i misse one little bolt and it popped right off......haha but thanks</TD></TR></TABLE>
Yep, been there.
If it doesn't just slide off then it's a bolt(s)
Yep, been there.
totsie7944
02-04-2008 08:34 AM
81CB900C
12
07-02-2007 04:44 PM
Mr. Softee
10
03-12-2003 03:09 PM
