V-Tec problem
Electrician
VTEC is ONLY supposed to turn on at times, not from when the engine is turned on. VTEC is actuated by oil pressure and RPM. Once a certain RPM and pressure is reached, VTEC engages.
DO NOT, I REPEAT, DO NOT CHANGE YOUR VTEC CROSSOVER POINT!
Unceasing Measure
Re: (lmiguelvv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmiguelvv »</TD></TR><TR><TD CLASS="quote">what happens is that v-tec doesn't open at all</TD></TR></TABLE>
It's VTEC. VTEC doesn't "open", it is a process that is activated when your VTEC solenoid links the rockers in the head to increase duration and lift of the camshaft. If VTEC isn't working all the time it's probably because you have a jury-rigged shitbox mini-me instead of one that's properly done. Maybe you're trying to run hard when the engine is cold or otherwise lacking in certain vital areas...I'm not sure because I'm not you.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">VTEC is ONLY supposed to turn on at times, not from when the engine is turned on. VTEC is actuated by oil pressure and RPM. Once a certain RPM and pressure is reached, VTEC engages.
DO NOT, I REPEAT, DO NOT CHANGE YOUR VTEC CROSSOVER POINT!</TD></TR></TABLE>
i thought that was the big thing was making vtec "kick in" early....
Re: (hondainspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired »</TD></TR><TR><TD CLASS="quote">
i thought that was the big thing was making vtec "kick in" early.... </TD></TR></TABLE>
Yes, among idiots these days, it is. Unless the engine it is changed on has EXTEME internal modifications and is very well tuned. Changing the VTEC crossover point is pointless and harmful to the engine. It will actually (in some or most cases) cause a lose of power.
* B A N N E D *
1 Post
Re: (DOHC4life)
I'm gonna back him up here. Your engine was OPTIMISED at that RPM to change cam profiles (engage VTEC). So unless you change your cam, and/or change like piston rod length, AND your engine was upgraded to handle any possible added stress, Yeah, DON'T CHANGE YOUR VTEC ENGAGEMENT RPM. Thats advice that will save you a headache and money.
Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">
Yes, among idiots these days, it is. Unless the engine it is changed on has EXTEME internal modifications and is very well tuned. Changing the VTEC crossover point is pointless and harmful to the engine. It will actually (in some or most cases) cause a lose of power. </TD></TR></TABLE>
Correct. You can end up haveing a loss inpower or even a blown motor if you do not do this properly.
