will BFG 225/50/15 drag radials fit on 99 SI wheels?
Re: will BFG 225/50/15 drag radials fit on 99 SI wheels? (greenmonster)
well im assuming the stock ones are 195s right. they'll fit on the rim the only problem you might run into is the bead seating correctly (seen this happen on low profiles to wide for the rim) or rubbing while you're turing cause they'll more than likely bulgelike a *****. take em to a tire place and have em test fitted.
Re: will BFG 225/50/15 drag radials fit on 99 SI wheels? (mat)
Check BFG's site or contact them. There should be some info on the approved rim widths for that size tire. Might even find it on tire rack.
