Does the distributor install one way only ?? need quick answer thanks
im about to reinstall the distributor but notice that the distributor can connect to the cam shaft either one way or if i turn the part that connects to the cam it will still fit.. does it matter?
on the distributor there are two prongs stiking out that connect to the cam but there is also a indented lined on top of the grooves does it matter when re installing the dist?? thanks
DarkFlame
01-16-2014 11:17 AM
