Rev Limiter is too early
I have a 92 Si with a '96 B18C1 with a P72 and for some reason, out of nowhere,my rev limiter is now coming on at 7400rpms, no CEL, no other problems, any one got any ideas?
Blue Sedan Crew
Re: Rev Limiter is too early (Bigtknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtknight »</TD></TR><TR><TD CLASS="quote"> any one got any ideas? </TD></TR></TABLE>
you hava a b16???????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtknight »</TD></TR><TR><TD CLASS="quote">I have a 92 Si with a '96 B18C1 ..... </TD></TR></TABLE>
what are you talking about?
Re: Rev Limiter is too early (darkcvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkcvc »</TD></TR><TR><TD CLASS="quote">
you hava a b16???????</TD></TR></TABLE>
he just said that he has a 96 b18c1 = GSR .. damn, im tellin you, DARKCVC .. go watch some Barney, Sesame Street, or Spongebob .. you'll catch up with the rest of the world..
anyway, try unplugging your battery for 5 minutes and turn it back on again.. then try again.. if this does not solve your problem, try to borrow someone else's working p72 ECU .. if the problem is fixed, it is your ECU ... but if the same problem exists, then it's your engine.. i hope that helped you out.
Re: Rev Limiter is too early (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">Try another tach. Yours may be off.</TD></TR></TABLE>
Try that next after the battery thing...that would be my guess.
Well the spedo is on, and i don`t think it would be off by 700 rpms....
any other ideas
any other ideas
i would stick with checking out a friends ecu to see if that works. also check the tach, stock tachs aren't the most accurate but i don't think i have ever heard of them being off by that much.
ok heres the deal, 96 Gsr swap in a 92 Si. idles fine runs good vtec engages intake mani opens up. did comp test, 225 across. every thing works fine......except the fuel cut kicks in a 6500rpms. swaped ECUs, same thing, changed distrebutor. Same ****. Have no idea. Offically Stumped......cmon i know this isn`t a freak problem, someone has had to have had the same thing, come through for me Honda-tech......
Re: (TypeRWanter)
This could be COMPLETELY unrelated, but I had the same problem. It didn't happen all the time though, but it was my VSS. My VSS was going out and that was causing the computer to go ape$hit. I would be driving down the street at 40mph and the speed limiter would kick in.
But like I said, I don't know if it has ANYTHING to do with what you are describing.
Re: (BauleyCivic)
Yes Vtec is engaging fine, theres no CEL light and, to my knowledge, everything is wired up right. wouldn`t a bad O2 cause a cel also?
Re: (Bigtknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtknight »</TD></TR><TR><TD CLASS="quote">Yes Vtec is engaging fine, theres no CEL light and, to my knowledge, everything is wired up right. wouldn`t a bad O2 cause a cel also?</TD></TR></TABLE>
I've heard 02 sensors may go out and it won't give you any cel. I'm not sure how to check to see if the o2 sensors are working properly. I'm guessing the tach might be off as well. Who knows. Try another ECU.
Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">
I've heard 02 sensors may go out and it won't give you any cel. I'm not sure how to check to see if the o2 sensors are working properly. I'm guessing the tach might be off as well. Who knows. Try another ECU.</TD></TR></TABLE>
already tried that
i`m not buying the whole Tach thing, i mean, off my 2000rpms
already tried that
Re: (Bigtknight)
This may be the onw that stumps the whole Honda Community, i`ve asked everyone i know and know one knows what the hell is wrong with my car I'M SO PISSED!!!!
