How do I make a fuel cut off switch?
Hey, I own a 00 SI and I want to make a fuel cut off switch. How do I make this and what materials would I need? I diagram or something would be nice. THanks.
Re: How do I make a fuel cut off switch? (jeffk182)
i want to do the same to my civic. i plan to use a toggle switch on the fuel pump just find the the wires cut one splice a toggle into it (add more wir to reach desired location of switch) and vwala
Re: How do I make a fuel cut off switch? (Luserkid)
DO NOT use the above directions...I made a topic a couple days ago search my recently created topics. Someone posted on there why it's wrong.
Re: How do I make a fuel cut off switch? (lax1185)
Why not? I used it and never have a problem. Worse thing that happend is the fuel pump fuse went out once. That was it.
What went wrong?
What went wrong?
Re: How do I make a fuel cut off switch? (Ej1_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe »</TD></TR><TR><TD CLASS="quote">worked for me.. off to go read why it is wrong.</TD></TR></TABLE>
Link me please
Link me please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 »</TD></TR><TR><TD CLASS="quote">DO NOT use the above directions...I made a topic a couple days ago search my recently created topics. Someone posted on there why it's wrong. </TD></TR></TABLE>
the wire gauge he was using was too big so it drew too much current and caused it to melt
don't do that **** to the fuel, every one and there momma does that ****. you need to run a switch to the ecu power. and I tryed that fuel pump **** and that **** sucks. it didn't work that good. I shut it off, and it ran for a min. and it died and then when I turned it back on it took for every to turn on. that **** was wack.
Re: How do I make a fuel cut off switch? (6gcivic)
heres a safe way to do it>>> go inside the car on your front passenger side and remove the kickpanel underneath the glovebox by the door..this is where your ECU is.. there will be a whole lot of wires but you have to find a yellow wire with a green stripe..there will only be 1 of them..make sure its not a green wire with a yellow stripe..just cut the yellow wire with the green stripe and run new wire from each end of it...run this new wire to a regular on/off switch..1 wire to each end of the switch..mount the switch to your desired location and put your kickpanel back on>>its real easy
Re: How do I make a fuel cut off switch? (jay.dee.em1)
what the hell does it matter if u do it up front or in the back? eather way does the same thing but if it melts which it proable wont but it would be under the dash.
i did it in the back under the seat fine no proablems for over 2 years. as far as the car still runing for like 1 min. the fuel has to burn all the way out.
