Spark plug choice.....
I'm wondering which spark plug would be better....Denso Iridium, NGK iridium, or other? I drive a 99 civic coupe (D16y8).
Give me an oppinion on which would be better.
Re: Spark plug choice..... (handa)
I thought it was the Denso Comercial version....that's why I was asking. But I'll check tommorow again when I take it out.
* B A N N E D *
1 Post
Re: Spark plug choice..... (JunY)
Search, and check the surveys. But in sum up, NGK Iridium is the BEST for your vehicle.
P.S. Those 4 ground plugs are all bling appeal. They are no better than a good NGK.
if its stock motor... i would just run stock plugs.... or a lil bit better then stock but ... i wouldn't bother running the iridiums or bosch platinums
(platinums blow in my opinion) but if NGKs are OEM standard... i would run those.. i havn't even looked to see whats sitting in my civic... bout ta hit 100k and i have a feeling they're the original plugs....
Re: Spark plug choice..... (MikeD718)
How much of a difference do you think it'll be if I do get a NGK iridium plugs over Denso iridium though? I just need oppinion on how much of difference it would make.
Re: Spark plug choice..... (civicvxhatch)
i have obx iridium
well no there not that good but really i don't feel a difference from my stock ones to these. I just needed new ones and these were cheap on ebay and i could tell people that there iridium, jdm y0 plugs.
I would go with OEM Honda which will be NGK
Buying anything else is a waste of money
The car at http://www.ericksracing.com/racecar.htm runs 9.9 Secs in the 1/4 Mile and puts out 300 WHP All Motor running stock ignition
So unless you plan to run faster then that go with OEM
