Help :: Starting a newly installed Engine.
I just installed a new z6 in my hatchback and having problems starting it up. Anyone have any tips going about this? Some detailed directions would be great. I did a search but there wasn't much detailed information.
Things I've checked:
- the spark plug wire sparks
- hoses
- fuses
- wiring
Any help will be greatly appreciated
- hoses
- fuses
- wiring
Re: Help :: Starting a newly installed Engine. (oxSLEEPERxo)
does the engine smell like fuel after you try to start it? (ie, are the injectors spraying?) Is your fuel pump kicking on? are you sure your timing is correct?
how far have you gotten it
do you have fuel
do you have spark
etc- need more information -
no cranking some thing must be miswired- cranking but not turning over- fuel or ignition most likly
do you have fuel
do you have spark
Re: (b204dr)
The engine is cranking, but it won't turn over. It does smell like fuel. As far as timing goes, this engine was removed from a running civic 3-4 months ago. It started right up back then, but it has just been sitting for the past 3-4 months. As for the plugs, everything is plugged in. I checked for spark by putting the spark plug wire next to a bolt and yes it sparked.
Re: (93delslo)
The spark plug wires are right. As far as ground, how many are there? One on the valve cover, tranny, and to the battery. those are the one ones i know of or can think of
Re: (oxSLEEPERxo)
Anyone have any more ideas? Post it here or IM me on aim "oxsleeperxo" Your help will be greatly appreciated.
I mis-used the word turning over in my previous post. The engine is turning over, but it's not starting. It seems like it wants to start but just wont.
Re: (oxSLEEPERxo)
you should check your timing... fuel filter... uhhhhhh... trying pumping the gas pedal while starting... haha that worked for my friends 4runner after it was sitting for months... i'd do the pumping thing last though...
Re: (2lua)
i would pull the plugs, check see if they smell like gas, Is there any kind of putter, or anything, even if you have the spark plugs wrong, you should get like a back fire or something. is it throwing any codes? give us the whole story. from start to finish. then we'll help somemore.
oxSLEEPERxo
03-18-2005 11:23 AM
oxSLEEPERxo
03-18-2005 10:14 AM
