rasing rev limter
rasing rev limter
i have a jdm b16a and it hits rev limit at like 7900 should i rasie it to make more power or is just not worth it because i heared of people making power all the way up to 8200 on them by the way how do i change my rev limter
Re: rasing rev limter (b16a27)
You need to go to a dyno first. that will tell you where you make your power. If you have stock valvetrane, you probably won't benefit from revving higher. To change it, you need a vafc or chipped ecu.
Just leave it alone. That's something to many people think is a good thing. "hmmmmm I'm gonna rev to 9000 rpm cause I'll go faster" BULLSHIT! First you DON'T WANT to have to rev the **** outta the engine to make power. Second, unless your engine is built you WON'T MAKE power that high. Third, high rpms kill engines. And last, you will most likely drop outta your power band if you rev high as **** once you shift.
Just leave it the **** alone. Oh and unless you have uberdata or hondata or a ECU chip, you CAN'T change the stock rev limiter.
VAFC's don't allow you to change your rev limiter. Otherwise my friend with a turbo GSR in his coupe would be reving to 9k right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parasonic »</TD></TR><TR><TD CLASS="quote">Let em learn his lesson..just throw the rod man, throw the rod :D</TD></TR></TABLE>
It's not even about the bottom end. He's more likely to float a valve than he is to throw a rod through the block. But even that isn't my point. It's the fact that reving and engine sky high WON'T make you go faster. If anything it will slow you down. No there are a couple exceptions. One being the spoon engine. That thing can and does rev to 10,000; BUT! they still make power up that high. And plus they are built to be put in race cars that are on tracks that require high revs.
Anyways, just leave it alone until you have reason enough to need to raise the rev limiter.
Re: rasing rev limter (SOHC4life 96)
You want to rev high and make power, get cams, valve springs, retainers, and a chipped ecu. with all those parts, you can make power up top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Just leave it alone. That's something to many people think is a good thing. "hmmmmm I'm gonna rev to 9000 rpm cause I'll go faster" BULLSHIT! First you DON'T WANT to have to rev the **** outta the engine to make power. Second, unless your engine is built you WON'T MAKE power that high. Third, high rpms kill engines. And last, you will most likely drop outta your power band if you rev high as **** once you shift.
VAFC's don't allow you to change your rev limiter. Otherwise my friend with a turbo GSR in his coupe would be reving to 9k right now. </TD></TR></TABLE>
angry but true!
angry but true!
